Tires 255/35R19
miche25
coaticook
audi RS3 - 2018
Has anyone ever used 255/35R19 tires on 19" wheels? on 4 wheels on a 2018 RS3? Is it possible ?
hk852
tf
Afghanistan
rs3
why tho?
napkintosh
Denver
CO
2022 S3 Prestige
255/35/19 is a factory option for 2018 RS3 in the front. I don't see why they wouldn't fit in the rear. The steering wheels are usually the ones you usually have to worry about.
RS3JM
Reading
2017 Audi RS3 400PS
255/30/19 should be factory and what I had. Mixed with 235/35/19 on the rear.
If you don't stager the tyres you end up with lots of understeer in the car. Also experiment with 44psi in front and 39psi in rears. This might depend what suspension your running vs how you like the car to respond.
Tyres wise, I destroyed a set of PS4's in less than 7k miles. They are pretty rubbish and have worn badly, will not buy again. Currenty testing out the best in market - Continental sports contact 7. They are harder ride but they bite better going into corners and launch better off the line. Yet to know what they are like in the cold.
