fixing my B108b71 fresh air, recirculation, air flap motor
Kansas City
MO
2017 Audi S3 Premium Plus
#21
any updates on this? I got the recirculation flap code this winter when my windows were fogging up and I tried to turn it off, once I cracked my sunroof all the hot air left the cabin and the defroster was able to clear the windows and windsheild of fog. I think the fresh air flap is stuck closed too
djsauce
Burlington
S016 S3 Technik
#22
Same here, two issues:
(1) Lots of condensation in the cabin, I have a fault (B108B54) related to the Fresh Air/Recirc air flow flap, I'm sure its stuck closed so no fresh air gets in? Is this the one on the far right of the dash (LHD vehicle) above the cabin filter, in the glove box? If so, how did you remove it, seems to be a common question.
(2) The two center vents don't blow any air, I removed the vents and moved the flap manually, it works when I pry it open, but it stuck closed. I have a fault related to Front air distribution door motor (B109154), are the center vents not blowing related to that, which motor is that and where is it located?
thanks!
Thread Starter #23
the motors are crap. they, like other parts from audi got out sooner than later.
Thread Starter #24
i have another motor go out on me. wonderful location as well. its the drivers side motor where its located way up above the cluster area.
using vcds I got this code. this is with my cobb ap installed. you will want to remove any mapping software on the ecu so that it will work correctly when you do the clearing with vcds or anything else you have.
328964 - Motor for Front Air Distribution Flap
B1091 71 [00001000] - Actuator Stuck
ill be attempting to buy the MES one and not the johnson version. but ill need to make sure once I remove the old motor unit.
View: https://www.youtube.com/watch?v=fhhyhXJSHPY&t=1s
