Audi s3 8y ideling issue
sokhyS3
Hi all, I have an Audi s3 8y just recently purchased. Not sure if this is the right area to post this so sorry in advance. Just wondering if it is normal for the car to idle higher when running warm. I noticed it happening when I was using my MMI system. Any help would be much appreciated. 👍🏽
benrst3
Wolverhampton
S3 8V
Did you get to the bottom of this issue? Mines been sitting at 1200 Rpm regardless of mode and once warm on and off for the last 6 months it’s been in 3 times can’t find the fault. It’s been doing it constantly for the last 2 days and now this evening has gone back to normal again?
too little info to help.
first you need to scan the ecu to see if there are any issues.
second. any aftermarket parts put on. any work done on the car.
third, how is the temp at your location?
Surrey
S3
I’m having this same issue thought it was the rad coolant temp sensor reading -50 but the actual value was good the specified value is the bad one reading -50, could this be an ecu issue or is it unrelated to my idle problem?
