6 beeps
Storme
WIMBORNE
hi all
i get 6 beeps on start up, from the dash board
i initially thought it was the battery, but that has been replaced and coded
the car shows no fault codes
the beeps are the same as the seat belt warning beeps, so defo from the dash............not from the alarm
sometimes, i get 3 beeps..............rarely i get no beeps
usually 6 beeps
it is going back to the dealer next week !!
any ideas?
as said, dash beeps...... not from the alarm
car starts perfect...no sign of drained battery...which is new
once the 6 beeps have sounded, i dont here them again, until i have turned off the car
then when i turn on again....back come
S
Storme
WIMBORNE
i will mention that to the garage, just strange its from the dash and not the alarm :)
S
Storme
WIMBORNE
it is soooooooooooooooooooooooooooooooo obvious........its stupid !!!!!!!!!!!!!!!!!!!!!!
if you put your seat belt on 1st, you get no beeps !!!
the problem with forums, is every one thinks the worst !!
i was told
low battery
low alarm battery
someone had cut the alarm battery
needed a new battery
Johnny
Guest
Who is stupid?
S
Storme
WIMBORNE
me !!
6 beeps means the seat belt isn't plugged in, and you've turned on the ignition !!!
which I had enabled via carista !! a month ago
