Glitter like metal in haldex oil ~ should I be worried?
Sammamish
WA
2015 Audi S3 Prestige
2015 Audi s3 prestige
My haldex was completely not working, I knew this by doing a launch and taking a slow-mo vid. After the technicians replaced the pump and the oil, they noted that the oil had little shimmering pieces of metal in it. The shop I took it to does specialize in Audis, but they might not know too much about the 8V S3 specifically. Since the old pump was completely not working, are those metal shavings expected? The haldex is now working with the new pump, but they told me I should be driving hard on it at all since some metal coupling on the haldex system itself is where the metal shavings are coming from. Should I be worried?
depends on how much metal was in there.
launching these things is always going to wear down components.
i personally dont launch. i had a manual car before and i attempted launches on those cars. i do my own repairs and maintenance.
i dont do launches anymore on manuals. the reason i say manuals because they have a much easier clutch replacement process.
with automatics, its amazing how they say its okay to launch them after knowing how automatics work. i would never do launches on automatics unless it wasn't my car.
i dont see much metal shavings in my oils. some but nothing I'm worried about or to even note about.
Audi_Ambassador
Sammamish
WA
2nd launch control within 5 mins I get a “transmission overheated, please adapt driving”
the message went away before I could even barely finish reading it. Am I ok? Is this normal? I was driving it pretty hard like I usually do before I went and did the launches. I don’t plan on launching ever again. I just want to know I haven’t messed up my transmission with this message popping up. Thank you
did you change out the fluids in the rear or the front trans?
D For Sale 0
D New Member Introduction 2
