Tilt right rear mirror
Pete_A
Stockholm
Sweden
Audi S3 8V Cabriolet 2016
Is it possible to enable function Tilt function for passenger's exterior mirror with ODB11, VCDS or similar on a S3 2016 8V?
RS3JM
Reading
2017 Audi RS3 400PS
Yes, I did this using my OBD11. Works well.
Careful how much you do with this tool, it can mess things up if you are not careful. Do 1 at a time, try it out then more. Just so you know if you get an issue, what it is. Few other good features they offer also, check out the app. By the Pro package and it opens up diags, which is useful if you need to reset your gearbox settings back to factor.
Use also the scans to identify but also clear errors on the car, it can effect how the car runs and performs.
Also easy with VCDS but mine is a 2017 (face lift 8V).
