Launch Control Parameters
NC
What are the parameters for launch control, such as min/max oil temp, coolant temp, transmission temp, etc? Sometimes launch control works and sometimes it doesn't. Trying to figure out if I have a problem or if I'm not within the correct temperature ranges.
I would hope no one is doing launch control on a cold car. A long as everything is up to operating temperature, you should be good to go.
Did you make sure you are in Dynamic mode and switch to manual shifting?
jfglass
GA
I suppose there is some ideal combo, but I usually just take the traction control off and shift the lever into "S" and it works even though I'm not in Dynamic but Individual. Seems to work just fine.
