Humming and squeaking noise
London
2013 Audi s3 8v
Hello guys I’m trying to figure out a humming and squeaking noise I had a look at my brakes on all corners re greased them as they was changed but no sign of any copper grease the squeak has gone down a lot but from the o/s/r there is a hum and squeak there’s no play from bearing sounds like wheels bearing but can put my finger on the issue :/ could be something simple but I can’t find it anywhere:/
robbobjm
Middlesbrough
2001 audi s3 8L+ 2001 audi a6 c5
Copper grease on brakes is a big no no, it dries out and causes problems, use wipe it off and use ceramic brake grease. Use a dti gauge and check the runout on the disks and did you follow the bedding in procedure properly?
Sent from my MAR-LX1A using Tapatalk
