DQ381 Gearbox fault
Portmore
Jamaica
2020 Audi S3
Can anyone tell me what most likely is the problem? The car will not rev past 3500RPM in the odd gears 1-3-5! Like it goes to limp mode..even gears are okay!
Grateful for support!
OBDeleven vehicle history log
Date: 2022-12-12 20:27:30
Car: Panther Black S3
Year: 2019
Body type: Saloon
Engine: DJHB kW ( hp) l
Mileage: 31466 km
02 Transmission
System description: GSG DQ381
Software number: 0GC300012M
Software version: 2302
Hardware number: 0GC927711H
Hardware version: H06
Faults:
P184A00 - Main pressure adaptation
Offset upper limit exceeded
Intermittent
Priority - 0
Malfunction frequency counter - 5
Unlearning counter - 255
km-Mileage - 31387 km
Engine torque - 40 Nm
Control module temperature - 52 °C
Coolant temperature - 105 °C
Accelerator position - 29.4 %
DTC memory status - 141
Clutch, primary stat - Fahren
Selected gear - GANG_4
Driving position - Tiptronic
Engine speed - 1836.00 1/min
Vehicle speed - 46 km/h
date - 2022-12-05 08:30:51
P175D00 - Clutch 1 opens unintentionally
Intermittent
Priority - 0
Malfunction frequency counter - 6
km-Mileage - 31331 km
Engine torque - -16 Nm
Control module temperature - 51 °C
Accelerator position - 15.3 %
DTC memory status - 89
Selected gear - GANG_5
Driving position - D
Engine speed - 1333.00 1/min
Vehicle speed - 45 km/h
date - 2022-07-24 13:59:29
P189800 - Clutch 1
Function restriction
Intermittent
Priority - 0
Malfunction frequency counter - 4
km-Mileage - 31408 km
Engine torque - 64 Nm
Control module temperature - 91 °C
Coolant temperature - 100 °C
Accelerator position - 39.6 %
DTC memory status - 216
Engine speed - 1449.00 1/min
Vehicle speed - 44 km/h
date - 2022-12-05 17:22:05
P081000 - Clutch Position Control Error
Intermittent
Priority - 0
Malfunction frequency counter - 1
km-Mileage - 31458 km
Control module temperature - 82 °C
Coolant temperature - 104 °C
Accelerator position - 27.8 %
DTC memory status - 270
Engine speed - 1383.00 1/min
date - 2022-12-12 16:57:54
