- 52
just found brailles new lithium car batteris.
these might be the next item once the stockers goes out.
positives:
Lithium delivers a higher, cleaner voltage which improves the performance of every electrical component and has shown to provide:
• Quicker starting (a full volt higher than lead and less voltage drop during cranking)
• Improved engine management & data logging performance (more stable voltage)
• Less horsepower draw from the alternator due to efficient charging (5 times faster than lead),
• Lasts 3-5 times longer (especially under the harshest environments),
• Much more reliable (less than 1% failure rate)
• Significant weight savings. (up to 1/4 the weight)
• Don’t self-discharge, so if the battery is disconnected (no draw or via power disconnect switch), they can sit for over a year+ and still maintain over 13 volts to start the vehicle.
negative:
price
website link:
braille car battery, lithium carbon
positives:
negative:
price
website link:
