- 27
- AZ
- 2015 Audi S3
I'll come back later an fill in the details, but here are some images that can help with your install.
Tools Needed:
Panel Removal Tool
Add-A-Circuit Fuse Tap Kit
10mm Socket and extra nut
Dash Cam
BlackVue Dash Cam DR650S-1CH - Link to Amazon
Remove the fuse box cover.
Remove the side cover.
Running the wiring
Wiring the camera.
Yellow Wire = 12v, Red Wire = ACC, Black = Ground
F38 and F48 can be used.
F38 has constant power and F48 is for ACC power.
Installing the ground wire.
Mounted camera
Tools Needed:
Panel Removal Tool
Dash Cam
Running the wiring
Wiring the camera.
Mounted camera
